Plow
Cable protection system with EMC protection
With the 'Protect' cable protection system, Pflitsch is launching flexible corrugated conduits and fittings made of polyamide, designed to meet the requirements of mechanical and plant engineering, automation and robotics, the automotive industry, the marine sector and railroad technology.
© Plow
The core range of the Pflitsch cable protection system consists of six corrugated conduit types, each available in coarse and fine profile variants. The components are approved for operating temperatures from -40 to +105 °C, the corrugated conduit for high-temperature applications even up to +150 °C. In addition to properties such as durability, abrasion resistance, mechanical and chemical resistance, 'Protect' offers flexibility as well as torsion and vibration resistance. It is also weather and UV resistant. Some versions meet the highest fire protection standards for rail vehicles in accordance with EN 45545-2.
The certified system is available in three versions: The basic version achieves protection class IP 66, while the version with an additional sealing ring on the corrugated pipe fulfills IP 68 and IP 69.
Thanks to the retaining ring, the 'Protect' fittings are compatible with all corrugated conduits in the series with a fine and coarse profile, which ensures a secure and permanent connection even in the event of vibrations. During installation, the corrugated conduit is locked into the fitting with a deliberate locking process, which increases the operational safety of the installation.
In order to achieve additional EMC protection for environments in which electromagnetic interference occurs, the company has developed the 'UNI Protect EMC', which ensures EMC protection on the fitting and in the corrugated conduit. This means that even unshielded cables can be upgraded to be EMC-safe. The corrugated conduit is provided with an internal metal braid for this purpose.
Rosenberger OSI
Data volume demands infrastructure
Big data, cloud computing, IoT, Industry 4.0 and digital workplaces - data growth is enormous and the digital transformation is changing the IT world forever. How must the cabling be designed so that the network infrastructure can cope with the data...
Plow
Securely bolted
The ease of installation and installation safety of EMC cable glands are decisive factors for system safety and the achievable shielding attenuation of the installation. What do modern solutions look like?
Plow
Completely EMC-safe
Where signal and power cables are routed through an enclosure wall, there is a gap in the shielding through which electromagnetic waves can 'slip through'. Raphael Brandt, Product Manager Cable Gland Systems at Pflitsch, explains what can be done to...
Cable glands
The seal adapts
A major challenge for manufacturers of machines and components is the variety of connection cables used by customers worldwide. What do you do if you don't want to supply a vast number of accessories?
Lapp
Authorized distributors made visible online
Lapp is expanding its digital service portfolio and is the first B2B industrial company to provide its authorized distributors with a verifiable online seal from authorized.by. The company aims to create more transparency and security for buyers and...
Habia
Axel Barnekow Widmark becomes CEO
Habia, a global supplier of customized high-performance cables, announces changes in the company's management: On April 1, Axel Barnekow Widmark took over the position of Chief Executive Officer. He succeeds Carl Modigh, who will remain with the...
Tsubaki cable towing
Avoid wear and tear
Tsubaki Kabelschlepp has added a new function to its condition monitoring system so that wear can also be monitored outside the chain without the need for additional cables in the cable carrier. The system also monitors the push/pull forces during...
