Frequency changers
Startup without specialist expertise
The current generation of frequency changers from Yaskawa combines functionality, flexibility and simplicity. Starting the series comes the GA700 model.
© Yaskawa
The units of this series can be put into operation speedily and without specialist expertise, and then operated with little prior knowledge. Requirements are the control panel with its lean interface for example, and functions for interactive, dialog-guided startup plus intuitive PC tools, smartphone apps and cloud services for parameter management and backup. At the hardware end installation is simplified by standard European power terminals.
IIoT gateways
Based on Raspberry Pi
With the RevPi-Connect, Kunbus introduces the newest member of its Revolution Pi product family to the market. The device, designed as an IIoT gateway for machine and plant construction, is housed in a DIN rail housing.
