KEB Automation at the SPS 2022Communicate securely via Profisafe
The Drive Controller Combivert F6 and Servo Drives S6 from KEB Automation offer integrated safety functions directly in the drive.
Thanks to its IP65/67 protection rating and compact dimensions, the S1-PAC.IP IIoT controller from Automata can be mounted directly on the machine. Its scalable performance and communication interfaces make it suitable for IIoT applications with a focus on communication or control systems for classic PLC and motion applications as well as a hardware basis for visualizations. The CPUs also perform these tasks in parallel. Ethernet interfaces, WiFi and 3G/5G modem create connections to the cloud or local networks and thus enable integration into SmartFactory structures. The OPC UA server serves as a standardized communication protocol. I/Os and drives can be connected via Ethercat. The IIoT controller also offers an expansion slot for local I/Os or additional fieldbus interfaces. In conjunction with Codesys as a soft PLC, even demanding automation tasks can be implemented.
SPS 2022: Hall 7, Stand 281
