Wittenstein
Inka Krischke | Tiffany Dinges,
Can be integrated into digitized machines
The planetary gearbox XP+ High Torque of the 'alpha Premium line' from Wittenstein alpha is a planetary gearbox with high torque density and torsional rigidity.
© Wittenstein
Cynapse', an integrable sensor module with data evaluation logic and the IO-Link communication interface, enables connection to digitized drive axes and machines. Machine tools, packaging systems, automated handling technology and special machine construction are particularly suited to using the gearbox.
As a high-performance extension of the 'XP+' family, the gearbox achieves significantly higher process, feed and lever forces, opens up additional dynamic potential and offers improved control quality, precision and repeat accuracy during positioning, according to the supplier.
The gearbox series starts as a coaxial planetary gearbox in four sizes, five available ratios and three output forms.
Lean technology
Easy to implement
Nabtesco
The gearbox makes the robot
How precise, strong and fast a robot is depends on the performance of the gearboxes used. In the white paper, you can find out what is important in the design and how your robot can also benefit from the properties of Nabtesco gearboxes.
