Pepperl+Fuchs at the SPS 2024
Heat-Resistant with Long Switching Distance
The high-temperature inductive sensors of the NBN...-F135 series from Pepperl+Fuchs offer a switching distance of up to 50 mm. The integrated IO-Link interface in the amplifier allows integration into Industry 4.0 applications.
© Pepperl+Fuchs
Sensors are available with variable cable lengths, and each component can be replaced individually. The inductive sensor sets can be used at temperatures up to +250°C, and the switching distance drift is typically below 5%. Sensor heads can be replaced without re-parameterization of the amplifier, and adjustment of the switching distance via potentiometer is unnecessary. The IO-Link interface enables continuous communication between control and field levels, including sensor head status and limit warnings for predictive maintenance. Additionally, a switch cycle and operating hour counter is integrated. Multiple sensor heads can be synchronized—both in SIO and IO-Link modes—when arranged in series. The devices are available with fixed cables or a detachable connector, with cable lengths between 1 and 30 meters to facilitate installation. Flush mounting on metal minimizes the risk of sensor head damage .
Pepperl+Fuchs at the SPS 2024: Hall 7A, Booth 330
Weidmüller
SPE vor dem Marktdurchbruch
Single Pair Ethernet (SPE) hat die Konzeptphase verlassen und erreicht zunehmend die industrielle Umsetzung. Im Mittelpunkt stehen dabei nicht nur höhere Datenraten und vereinfachte Verkabelung, sondern vor allem die Frage der Systemintegration in...
Bihl+Wiedemann
Zukunftssicher automatisieren
Lapp
