TWK Electronics
Inductive displacement transducers with IO-Link
IO-Link is now also available for TWK's inductive displacement transducers. Their modular design allows the position transducer to be combined with the IO-Link electronics module IEIO25, which complements the 'IE25' series of electronics modules with SSI and CANopen interface.
© TWK Electronics
The models 'IW10' (up to 8 mm measuring stroke), 'IW101' (up to 15 mm) and 'IW120' (up to 200 mm) from TWK Elektronik are available as displacement transducers. A cable with an M8 connector is used to establish the connection to the IEIO25 module, which can be placed a few meters away and communicates with the IO-Link master via the 3-wire cable with an M12 connector. The IEIO25 scans the coil system of the position sensor and transmits the position value via IO-Link with 12-bit resolution and a cycle time of less than 5 ms. Additional bytes for the controller temperature and an error bit in the event of an error are also transmitted via the process data. The controller can execute a position preset or load the default values via the control byte (output data of the master).
TWK
Safety for AGVs
TWK presents the TxSN sensor model with magnetic sensor system in the series of functionally safe sensors with the CANopen Safety interface standard (EN 50325-5).
Bihl+Wiedemann
Innovation partner for automation
Bihl+Wiedemann is a medium-sized, owner-managed company - founded in 1992 by Jochen Bihl and Bernhard Wiedemann in Mannheim. It develops and manufactures complete solutions for functional safety and data communication in machines and systems.
EUCHNER
Customized solutions for smart automation
In a world of increasing automation, functional safety is essential. Plant operators not only have to comply with legal requirements, but also ensure efficiency and availability. For more than 70 years, EUCHNER has been supplying customized...
IO-Link
Second Test Lab in China
At the end of May 2024, the China-based company Nanjing Loyst Industrial Networks was recognized as a new IO-Link test lab. This brings the number of IO-Link test labs worldwide to four.
