Bosch Rexroth
I/O portfolio and safety control
Bosch Rexroth is now launching its own I/O line on the market for the first time. With the ctrlX I/O, the sensor/actuator level is to be seamlessly integrated. In addition, a safety solution has now been added to the portfolio.
© Bosch Rexroth
The new product is ultimately a functional extension of the ctrlX Core control system and features technology and hardware options such as additional memory and USB or Ethernet interfaces. The I/O module is based on Ethercat. However, Profinet and IO-Link are also supported. A total of more than 30 communication standards such as OPC UA and MQTT are designed to enable seamless connection to IT and IoT systems. By using encoder interfaces and drive modules, small motors and stepper motors can be controlled directly from the I/O level. Machine manufacturers can freely combine modules and extensions. According to Bosch Rexroth, apps tailored to ctrlX I/O from the CtrlX Works software and Engineering Toolbox cover numerous technological functions. The module has the same form factor as ctrlX Core and offers up to 16 I/O points across a width of 12 mm.
Safety on board
ctrlX Safety is based on two components that can be used independently or as a complete system: SafeMotion and SafeLogic. The hardware is very compact. Graphical programming allows the required programs to be created quickly and easily without extensive training. For more demanding applications, the hardware can be expanded with additional I/O modules via the safe fieldbus. The system has flexible interfaces such as digital I/O, ctrlX Safetylink, Safety over Ethercat (FSoE) and Profisafe (in preparation).
Bosch Rexroth
With lifetime lubrication
The EMC electromechanical cylinders from Bosch Rexroth are now available with significantly extended lubrication intervals. According to the supplier, many applications even benefit from lifetime lubrication, meaning that the cylinders in these...
ISH
Generation change heralded
ISH Ingenieursozietät, a member of the Austrian Neuron Group since 2018, has appointed Thomas Lehner as its new Technical Managing Director. He will be supported by company founder Axel Helmerth and Commercial Managing Director Michael...
Bosch Rexroth
Opening for partners
ctrlX Automation from Bosch Rexroth is an open ecosystem with applications for any automation task. Users can use apps from Bosch Rexroth, third-party applications or apps they have created themselves.
Now available
The e-paper of the November 11 issue
The e-paper of issue 11 is here. Among other things, you can read about Huawei's position in relation to the company's accusations of spying, why TSN is "a symbol of the standardization of fieldbuses" and how Single Pair Ethernet will change process...
