Surveying
Flexibly customizable
LSC 200 is a complete system for tasks in intralogistics and packaging technology, in which the sensors and evaluation unit are optimally matched to each other, according to the manufacturer Leuze.
Depending on the application, sensors can be used for object measurement and object detection. The software pre-installed on the evaluation unit takes care of data acquisition and pre-processing and, depending on the task, user data extraction. The user data is made available to the user via defined interfaces such as Profibus or TCP/IP. Due to its flexible adaptability, the surveying station can serve as a platform for different tasks, whereby the connected sensors differ depending on the task: For example, it can be expanded with sensors for identification, such as barcode readers. For example, dimensions can be measured using three light curtains (length, width, height) using the optical one-way measurement method. If the constellation requires it, width and height measurement can also be carried out with scanning light section sensors or laser scanners. Length measurement can optionally be carried out using incremental encoders. Depending on the sensor used and the properties of the objects to be measured, various filters can be set in the evaluation software to optimize the measured values. The adjustment of parameters, for example the offset adjustment when using light curtains, can be carried out using the GUI.
