Pepperl+Fuchs
Christian Güntert, Carsten Heim, Armin Hornberger | Inka Krischke,
Faultless battery production
The journey to climate-neutral private transportation takes place in the electric car. At its heart is the lithium-ion battery, whose fully automated manufacturing process, which should be as error-free as possible, requires high-quality sensors at key points.
© Pepperl+Fuchs
The alkali metal lithium (Li) has particularly mobile ions and therefore enables the production of power storage units with a high energy density. As with smartphones or tablets, the term 'rechargeable battery' should actually be used, but the term 'battery' has become established for the rechargeable unit in electric cars. This consists of thin layers of foil, each with a lithium-coated cathode, a separator foil and the anode, which is usually coated with graphite.
A liquid compound (slurry) is applied to coat the electrode foils. After the drying phase, they pass through a rolling mill (calender), where they are compacted at high pressure and at the same time given their uniform thickness. In order to achieve the desired result here, the films must maintain a defined speed as they pass through the rolling mills. At the end of this process step, they are wound onto rolls. The rotational speed of certain rolls in the calender is measured using encoders. The winding distance and material stock can be derived from the speed. The value is also used to control the material feed and allows the correct web tension to be set.
Precise measurement of the roller speed
The 'ENI90' encoder series from Pepperl+Fuchs is ideal for this task. The devices with IP65, IP66 or IP67 protection use BlueBeam technology for reliable speed measurement: Their blue light with a wavelength of 460 nm minimizes signal flutter (jitter). At the same time, it enables an optimized signal amplitude and therefore a significantly higher resolution than other light colors. The underlying optical effects generate an intrinsic resistance of the signal to mechanical influences such as vibration and shock. The fine structures of the scanning chips also contribute to the efficiency of the signal generation and the high signal quality. The absolute accuracy is marked by the maximum deviation of ± 0.025°. The signal is transmitted via a universal output driver or an RS422 interface.
Recognizing wafer-thin arches
Batteries in the form of pouch cells are predominantly used for electric cars, which enable a high energy density with optimum use of space.
The double sheet control 'UDC-18GS' prevents double layers of one polarity.
© Pepperl+Fuchs
To produce the cells, suitable pieces are punched out of the electrode and separator foils and joined together in the correct order. The cut foil sheets are picked up with vacuum grippers and positioned on an alignment table. In the next step, they are stacked alternately in the correct sequence by a second vacuum gripper. During the entire process, it is important that the gripper only picks up one of the very thin film sheets at a time. However, it can happen that several layers stick together. In this case, or if no film has been gripped at all, stacking must be interrupted and corrected. This is ensured by the automatic layer control on the alignment table. A double sheet sensor from the 'M18' series reliably detects whether there is one, no or several sheets on the table. In the event of incorrect stacking, the process is interrupted. This prevents double layers with the same polarity from reducing the battery capacity.
Ultrasound cannot be irritated
The ENI90PL for precise speed measurement and improved positioning when punching out film sheets
© Pepperl+Fuchs
Detection is contactless using ultrasound and without any impact on the sensitive films. The ultrasonic measuring principle is intrinsically robust: detection is completely independent of surface properties such as color and reflection behavior of the target material, which in this case is often very shiny. The sensor function is not affected by vibration and other mechanical influences from the machine.
The parameters of the measuring process can be precisely adapted to the thickness of the wafer-thin films by simple teach-in. The device can also be integrated into the system control via IO-Link. The IO-Link interface enables access to the sensor parameters as well as all diagnostic and process data. This includes, for example, the detailed evaluation of amplitude values or the simple commissioning and parameterization of the sensors. With the automatic synchronization of the devices, several ultrasonic sensors can be used simultaneously in a confined space.
All there?
Armin Hornberger is Head of Product Management Industrial Vision Components at Pepperl+Fuchs in Mannheim.
© Pepperl+Fuchs
The cells are created from the connected film layers and are then assembled into battery packs in a subsequent step. Here it is important that all cells are actually present and in the correct position in the specified grid. Ideally, the correct placement is checked fully automatically during the ongoing process while the battery packs are moving on a conveyor belt or roller conveyor.
What is needed here is a fast, non-contact and detailed inspection at close range. The 3D-capable vision sensors from the 'Smartrunner 3-D' series are ideal for this task. The device version suitable for this application is equipped with a stereo camera with a resolution of 1.4 megapixels each. The sensor can be easily aligned in the application using one or two 2D images. The sensor then automatically superimposes the two 2D images and generates a disparity image containing the depth information.
Christian Güntert is Head of Product Management Encoders, Inclination and Vibration Sensors at Pepperl+Fuchs in Mannheim.
© Pepperl+Fuchs
This data is used to generate a 3D point cloud image that shows the detected object in precise detail. The measurement data is pre-processed in the sensor's integrated FPGA. Among other things, the controller receives optimized depth data from the z-direction. On this basis, the actual situation can be compared with the required arrangement. Only when everything is correct is the production step for connecting the cells initiated. The three-dimensional recording makes it possible to carry out the inspection step in a single, fully automated pass.
The Smartrunner package includes the ViSolution user software with intuitive user guidance for commissioning. Parameterization can be carried out using live data; only a few clicks are required to visualize 2D and 3D data. No recalibration is necessary when replacing devices according to the plug & play principle. The device's Ethernet Gigabit interface ensures fast data transfer.
Hanover Fair
HANNOVER MESSE DAILY Day 4
The top news from the fourth issue: Robert Habeck at the trade fair tour +++ Technological AI highlights from Beckhoff +++ Radar sensor technology in focus at Pepperl+Fuchs +++ ASi-5 counter module as an active distributor from Bihl+Wiedemann +++...
