Security
Quelle: T&G Automation | Inka Krischke,
Protect critical systems
IT security is mainly concerned with data, while Operational Technology (OT) is primarily concerned with machines and systems, with the focus here being on the safety of people, the environment, quality and performance.
© T&G Automation
OpShield from T&G was developed to secure critical infrastructure facilities, control systems and all operational technology in general. With this solution, the provider relies on intelligent segmentation of plant and machine networks to prevent unauthorized access at command level. OpShield inspects, controls and protects OT protocols such as Modbus OPC or Profinet, guarantees full security transparency of the OT network and simplifies security administration, for example by integrating SIEM (Security Information and Event Management) solutions. The solution can also be installed in existing environments without the need for network redesign or downtime.
Drives
Common DC link coupling
Siemens is adding additional power and supply voltage variants to the Sinamics S210 single-axis servo drive system for mid-range applications. In the first new size, the system is available with an output of 0.4 to one kilowatt at 3 AC 400 volts.
Refrigerators
Also available in stainless steel
The stainless steel versions of the Blue e+ cooling unit series from Rittal have been specially developed for demanding environmental conditions, for example for applications where a high level of corrosion protection is required, such as in the...
Data routing
Protocol-independent connection
Production in I4.0 is based on the networking of machinery data with traditional IT applications. The availability of process data allows applications such as control stations, big data analytics, predictive maintenance and KPI monitoring to be...
