Ateg
Keyboards with glass surface
Ateg offers capacitive PC keyboards with a glass surface from the French manufacturer Tactys. The glass of the user interface is made of 3 mm thick, hardened white glass, which is robust against mechanical influences.
The keyboards can be cleaned quickly and thoroughly thanks to their flatness, seamlessness and smooth surface. The largely seamless housing supports the level of hygiene protection and can be thoroughly disinfected. For cleaning, the electronics are switched to sleep mode to prevent unintentional actuation. The user uses a dedicated lock button on the keypad for this purpose. The product portfolio consists of a compact keyboard and a keyboard with an integrated touchpad, both of which are available as wired USB and wireless Bluetooth versions. The Ateg devices work plug-and-play and are ready for use once connected to the PC. All common Western European country versions are available as standard; others can be implemented on request.
