HMI software
Quelle: GTI-control | Lukas Dehling,
Designer with new interface
With version 6.1, the HMI software Procon-Web has been given a new interface for the designer function - more closely based on solutions such as Microsoft Visual Studio.
© GTI-control
In addition, the server components have been redesigned so that many different versions can now run simultaneously in one system. The online project update and diagnostics have been further optimized and expanded. The revision of the table function should improve performance and simplify handling in the client. There are also new features with regard to the OEM versions of the system: In addition to the logo and splash screen, the Designer can be configured to the functionality of an embedded system so that only the target-specific function is visible and configurable via the interface. The devices are upwardly compatible throughout, which should enable users to update easily by adopting the previous configuration.
Packaging machines
Flexible HMIs
New operating concepts are placing increasing demands on HMI systems - including for packaging machines. Christ Packing Systems relies on HTML5 technology with responsive design and gesture support.
Building automation
Modernization via SCADA
Adding a SCADA system to an existing building automation system - that was the approach taken by the operators of the Stockwerk office center to modernize the building management system. A standardized interface between the control system and...
