Optris
Automated condition monitoring
The 'Xi 410' infrared camera from Optris combines features of infrared cameras and infrared thermometers. It has a Fast Ethernet interface and can be supplied via PoE.
© Optris
The integrated 'Auto hotspot finder' function reliably measures the temperature of moving objects without the camera having to be readjusted by Optris. If the network connection fails or there is a problem with the connected PC, the camera performs its task fully autonomously and ensures a seamless alarm in the event of a detected problem. This feature makes it suitable for safety-relevant applications in the field of preventive fire protection or condition monitoring on machines and systems.
In addition to the Ethernet interface, there is also a USB 2.0 interface for configuring important parameters and a direct 0/4-20 mA analog output. Via an external process interface, up to nine freely definable measuring fields can be further processed as analog outputs (either 0/4-20 mA or 0-10 V) or output as alarms via relays.
Kistler
WLAN-capable process monitoring
Kistler has added new features to the ComoNeo process monitoring system for integrated injection molding production: The pressure curve in all cavities can now be monitored more precisely with a process-adapted envelope curve.
Hexagon
Modular blue laser line scanner
Hexagon Manufacturing Intelligence introduces the 'Absolute Scanner AS1' with an automatable data capture rate of 1.2 million points per second and interoperability between mobile measuring arm and laser tracker systems.
EVT
Non-destructive testing
With the solutions for non-destructive testing (NDT) in the image processing software 'EyeVision 4' from EVT, the extended command set for NDT is available. According to the provider, this simplifies the detection of cavities or other structures...
AMA Innovation Award 2025
Submit applications now
The AMA Association for Sensors and Measurement (AMA) is calling on scientists and developers from industry and research to apply for the AMA Innovation Award 2025. We are looking for research and development results in sensor and measurement...
Janitza
Management expanded
Axel Hessenkämper joined Janitza as the new Chief Executive Officer (CEO) on September 1, 2024 and is part of the management team alongside Mr. Janitza, Mr. Müller and Mr. Veidt.
