Codesys
Safe programming of PLCs
In collaboration with Codesys, Fraunhofer IEM has integrated static code analysis development methods into the Codesys development environment commonly used for PLCs.
© Codesys
This integration provides software developers in the automation industry with real-time information on errors in their code, which they can correct during the development process. The solution is integrated in the 5.0.0.0 release of Codesys Static Analysis. Similar to a spell checker, the static code analysis indicates errors and dangers in the program code as early as possible. It also makes unintended data flows or the incorrect use of programming interfaces visible. Software developers can thus check and correct their code during programming without having to compile and execute it. For real-time correction, the research institute used distributive analysis frameworks with low memory consumption. The analyses offer programmers extensive configuration options and can be applied both to the Codesys programming interface and to integrated third-party libraries.
Codesys
Audi uses virtual control
In future, Audi AG will operate production lines with server-based control systems. Audi intends to use Codesys technology for control virtualization - both for functional and safe controls.
Codesys
Update for security applications
With the Codesys Safety SIL2 add-on, manufacturers can certify their Codesys-based control units, ECUs and PLCs for safety applications in accordance with IEC 61508 for SIL2 or EN ISO 13849 up to PLd with significantly reduced effort.
KEB Automation
Control drives safely
Functional safety is intended to minimize the risks posed by technical equipment to people and the environment. The drives from KEB Automation offer scalable safety functions directly in the drive controller for this purpose.
ProCom
Automation division becomes independent
The automation division of ProCom will be managed as an independent company in future. This is a consequence of the takeover of ProCom's energy division by the investor Volue ASA, which makes it obligatory to separate the 'Energy' and 'Automation'...
