Terminal blocks
Quelle: Weidmüller Interface | Lukas Dehling,
Installation height of 24 mm
Weidmüller offers the JB 25-50 and EBB 25-50/16 terminal blocks for decentralized equipotential bonding. They are designed to enable the installation of a ring cable in 25 to 50 mm², which brings together the potentials in the entire building.
Stub lines with 16 mm² can be realized from the ring conductor. According to the manufacturer, the terminal blocks safely equalize potential differences. Equipotential bonding prevents undefined currents, which can cause faults and malfunctions. Compared to star wiring, decentralized equipotential bonding is said to offer potential savings. With it, there is no need to run long conductor lengths from the individual field components to the busbar, only short stub lines to the terminal block on the ring conductor. The equipotential bonding terminal blocks have an installation height of 24 mm. All clamping screws of the equipotential bonding terminal blocks have the same width across flats, which is why it is not necessary to change tools during installation.
Weidmüller
Prepared for failures
Weidmüller relies on in-house developments to monitor its own ventilation systems for electroplating: The performance parameters are analyzed by the 'u-sense vibration' and 'energy direkt' sensors and with the 'Industrial AutoML' AI software.
PTC
Spatial Computing - The Status Quo!
The term spatial computing dates back to 2003 and stands for the interaction between man and machine. The technologies virtual reality, augmented reality and mixed reality in particular stand for this term. Is spatial computing revolutionizing the...
