Turck at SPS Connect
Inka Krischke | Tiffany Dinges,
Direct cloud connection
According to Turck, the TBEN-L-PLC is the first IP67 controller for industrial use that has a Codesys PLC on board, enables a direct cloud connection and can communicate simultaneously via various Ethernet protocols thanks to multiprotocol technology.
© Hans Turck
In dual MAC mode, the robust block module offers two IP addresses and can thus either establish a connection to the automation network via one port and a securely separated Internet connection to the cloud via the second port or - if no cloud connection is required - communicate in two Ethernet networks, for example as a Profinet device and as a Profinet, Ethernet/IP or Modbus TCP master.
With the option of direct connection to Turck's 'Cloud Solutions' directly on the machine, the IP67 controller not only eliminates the need for additional edge gateways, it also significantly simplifies project planning for the user. Decentralized and networked automation concepts can thus be implemented with little installation effort and cost. Programming such a solution with an integrated cloud connection also saves a lot of resources compared to applications with a separate edge gateway, as no interfaces are required for data exchange.
Easy access to machine data in the cloud from any PC or mobile device worldwide facilitates fault diagnosis and maintenance as well as condition monitoring for preventive maintenance.
The cloud interface clearly displays the status of sensors and other machine data in a browser application. The user can compile these dashboards without any programming knowledge.
Limit values, such as for temperature, pressure or vibration, are easy to set and actions can be defined if they are exceeded. The cloud sends an SMS or email directly if required.
Would you like a little more?
First-hand news every week - that's what the Computer&AUTOMATION newsletter offers you.
© WEKA Trade Media
Subscribe to our newsletter and keep your finger on the pulse of automation. Stay up to date with us. We provide you with the latest news, exciting interviews, guest commentaries, application-oriented technical reports and new products.
Click here to subscribe.
Turck
Paving the way for digital transformation
Automation solutions from Turck support the profitability, efficiency and sustainability of machines and systems. In this way, they not only increase competitiveness, but also contribute to more environmentally friendly production and intralogistics.
