Kunbus at the SPS 2021
Alternative to PLCs
The RevPi Connect+ feat.Codesys from Kunbus can be used as a modular and powerful small controller for a variety of different automation tasks and, according to the provider, represents an alternative to complex and cost-intensive PLCs.
© Kunbus
The 'RevPi Connect+' base module can be supplemented with a large number of digital and analog I/O and gateway expansion modules, which can be seamlessly integrated into Codesys and controlled and configured via the integrated development environment.
As the Codesys runtime natively supports many fieldbus and industrial Ethernet protocols such as Profinet, Ethercat, Ethernet/IP or CANopen, the 'RevPi' can be used as a soft PLC in such networks. With the included 'Codesys WebVisu', user interfaces or visualization masks can be generated and displayed on PCs, tablets or smartphones via all common browsers. This eliminates the need for separate HMI software.
Kunbus at the SPS 2021: Hall 5 Stand 228
Kunbus
IPC based on the Raspberry Pi
Revolution Pi is an open, modular industrial PC from Kunbus based on the Raspberry Pi. Housed in a slim top-hat rail housing, the three available basic modules can be expanded with a variety of suitable I/O modules and fieldbus gateways.
Kunbus
UL certification received
Kunbus has received UL certification for its open source IIoT gateways RevPi Connect. This means that all base modules in the 'Revolution Pi' family are now approved in accordance with UL standards.
akYtec
Control portfolio expanded
AkYtec has new controllers, process displays and cloud services for industrial and building technology applications in its portfolio. The focus is on compact devices with integrated visualization and extended communication functions.
