Embedded Box PCs
Quelle: ICO Innovative Computer | Inka Krischke,
Use in the machine and company network
Despite its compact dimensions of 100 mm x 115 mm x 31 mm (WxDxH), the Hygrolion 67 embedded box PC has everything necessary for easy integration into the respective network, according to the manufacturer ICO.
© ICO Innovative Computer
Two Gbit LAN connections and an additional WLAN connection enable combined use in the machine and company network or direct access to the internet. The computer can receive measurement data via the two integrated USB-C and USB-A interfaces as well as via Bluetooth 4.0 and, for example, process the data as an IoT gateway and forward it to the cloud server. Two additional antennas increase the range of the Wi-Fi. The VESA mounting points allow it to be attached to monitors or displays or even directly to walls or machines. An additional display port can also be used for control or monitoring tasks. An Intel Celeron N3350 with a clock speed of 1.10 GHz is used as the processor. However, the processor can also dynamically increase the computing power to up to 2.40 GHz, which is sufficient for most IoT tasks. The processor is supported by 4 Gbytes of RAM and a 64 Gbyte eMMC for the operating system and data. The computer is equipped with IP67 protection for the necessary robustness.
OPC Foundation
OPC UA from the cloud to the sensor
OPC UA is also establishing itself as a standard for the exchange of process data between controllers. The next step is now to extend the concepts developed for the controller-to-controller use case for the controller-to-device and device-to-device...
Delta Logic
Update brings support for TIA V19
Delta Logic has updated the 'Accon OPC UA Server' software to version 1.4.0.0. The new features include support for TIA Portal projects of version V19 and for the latest firmware for CPUs of the Siemens S7-1200 and S7-1500 controllers.
SPS 2024
Automation meets innovation
SPS - Smart Production Solutions will take place in Nuremberg from November 12 to 14. Once again this year, organizers and exhibitors will pick up on the trends in the automation industry and present suitable solutions. The introduction of IT into...
ISW Stuttgart
TSN in combination with EtherCAT
TSN is an important building block for convergent communication in flexible production. Mastering and integrating existing fieldbus technologies such as EtherCAT is an important part of the transition. An inventory of what is already possible.
