Peak system
Optionally with Ethernet
The PCAN-Router Pro FD, a 6-channel CAN FD router and data logger from Peak-System, is optionally available with an RJ45 Ethernet interface.
© Peak Systems
The hardware can be programmed with its own firmware, which is uploaded via the CAN bus. The development package supplied by Peak-System contains various C/C++ programming examples for using the PCAN-Router and its Ethernet interface. When delivered, the PCAN-Router is equipped with firmware for recording CAN 2.0 and CAN FD data traffic. The configuration of the CAN channels, the IP connection and all recording settings is done via a text file and does not require any programming knowledge.
The configuration and trace files are stored on the internal 16 Gbyte eMMC memory or on an inserted SD card. The memory is usually accessed via a USB connection. If the Ethernet interface is available, the data can be transferred via the connected IP network using FTP.
Peak system
Data exchange via CAN FD
The I/O module PCAN-MicroMod FD from Peak-System is now also available with ready-made motherboards in a black aluminum profile housing in addition to its use as a plug-in module in in-house developments.
Embedded AI
Embedded in the heart of the software
Artificial intelligence has become an integral part of everyday industrial life. But not all AI is the same. Its successful use depends much more on how well the AI functions are integrated into workflows, how practically they are used and how...
Neuron Automation
Functional Safety - Works!
With the certified safety modular system from Neuron Automation, OEMs can implement functionally safe control solutions faster, more flexibly and more cost-effectively - from hardware and firmware to the application. Functional safety 'in time', 'in...
