Compmall
Embedded PC for AI applications
Compmall has a new embedded PC in its range for AI applications in the industrial sector with limited space requirements, for example for on the edge at the machine.
© Compmall
The 'Elit-1060' model series from Compmall basically comprises two versions. The version prepared for AI contains Hailo-8 Performance, the basic version comes without this feature. The Hailo-8 version contains a Celeron N-6210 Dual Core processor with a base frequency of 1.20 GHz. The maximum frequency can be increased to 2.6 GHz. In addition, the Hailo-8 AI acceleration module is pre-installed via the M.2 M-Key interface. This allows up to 26 TOPS to be achieved. The frames per second (FPS) capacity was benchmarked at 2.5 times that of the Jetson Orin Nano 4BG.
The Hailo-8 AI processor with low power consumption (2.5 W) and high performance is suitable for demanding tasks with special hardware and software, especially in the fields of robotics, machine control or for applications such as crowd analysis and other AI applications. With this AI accelerator, the embedded PC is suitable as an edge computer. Up to 32 Gbyte DDR4 SODIMM can be provided as RAM. Graphical output is provided via a display port and two HDMI interfaces. Two 2.5 GbE interfaces are available for secure data forwarding. Optionally, WIFI-6, Bluetooth or 4G/5G can be implemented via the M.2 E-Key2230 interface. With 1x RS232/422/485, 2x USB 3.2, 1x USB2.0 and 2x USB Type-C 3.2, various options are available for connecting peripheral sensors, actuators, cameras or other sources.
Wöhr
Two new surface-mounted keyboards
Wöhr is expanding its 'Surta' industrial keyboards with versions 15 and 16, which have been specially developed for environments such as medical and dental areas, the pharmaceutical, clean room and food industries, as well as general industry and...
