Bachmann electronic at the SPS 2025
Panel PC with scalable equipment
Bachmann is launching a new product family of panel PCs onto the market: the 'PPC1200' will replace the established 'OT1200' in the course of 2026.
The Panel PC from Bachmann is available in two versions: The Eco version has an Ethernet and two USB 2.0 ports. In addition to two additional USB 3.0 and Ethernet ports and a microSD slot, the Premium version also has an HDMI connection and can also be individually supplemented with numerous interfaces, for example to connect a UPS via the serial RS232 interface, to set up a RAID1 system using a second microSD card or to increase network security with additional Ethernet connections. The Panel PC uses Intel Atom processors with two (Eco) or four cores (Premium) and has LDDR5 memory modules with 4 or 8 Gbyte capacity. Thanks to onboard mass storage of 4 or 16 Gbytes, large applications with their data and alarm history can be stored directly on the base units. The data and application memory can also be expanded via the microSD slot. The device can host any browser or Linux-based applications from the areas of Edge, HMI, SCADA, BDE/ERP clients and engineering.
Hall 7 Stand 281
