Box PCs
4K resolution possible
The Embedded Box PC series BP-IVH9200MXC from Plug-In is designed for the extended temperature range between -40 and +75 °C. The LGA1151 socket supports the Intel Core Kaby Lake processors ...
as well as the Intel Xeon/Core processors with the Intel C236 chipset and dual-channel DDR4 2133 MHz ECC memory - expandable up to 32 GB. The Intel HD Graphics 530 processor supports DirectX 12, OpenGL 4.4 and OpenCL 2.0 API. The fanless embedded system also has onboard DVI-I, DVI-D and DisplayPort display interfaces for Ultra HD 4K resolution. A 6 to 36 V power supply with 80 V overvoltage protection and EN 50155 and EN 50121-3-2 certifications are designed to ensure smooth operation. The system series also has features such as 6× GigE LAN ports with 4× IEEE 802.3at PoE+ without additional power connections, 4× front-access 2.5-inch SSD/HDD trays with RAID-0/1/5/10 data protection, 3× SIM card slots for 3G/4G/LTE/WiFi/GPRS/UMTS, 1× front-access CFast slot. It also offers 8× USB 3.0, 4× COM-RS232/422/485 and 4× SATA III (6Gbps) ports.
