Bihl+Wiedemann at SPS Connect
Inka Krischke | Tiffany Dinges,
Up to 16 digital I/Os possible
The first products in the Bihl+Wiedemann family of self-configuring I/O modules are the two ASi-5 modules BWU4230 and BWU4231 in protection class IP67, each with 16 I/Os.
© Bihl+Wiedemann
Depending on the application, up to 16 digital inputs or outputs are possible, for example in the form of a connection of twelve distance sensors and four valves in a packaging machine. The possible areas of application range from motor control and signaling to control panels.
According to Bihl+Wiedemann, the modules do not have to be pre-configured for their use, and a change of use can be implemented without additional software. The channel-specific diagnostics make it possible to individually detect an output short circuit or an overload of the sensor supply at each connection.
The status of set digital outputs can be read via the cyclical feedback so that faults can be localized and rectified quickly. In both modules, the inputs and outputs are supplied from AUX, the connection to the peripherals is realized via eight 5-pin M12 sockets. The BWU4230 is connected to ASi via profile cable, the BWU4231 via M12.
Would you like a little more?
First-hand news every week - that's what the Computer&AUTOMATION newsletter offers you.
© WEKA Trade Media
Subscribe to our newsletter and keep your finger on the pulse of automation. Stay up to date with us. We provide you with the latest news, exciting interviews, guest commentaries, application-oriented technical reports and new products.
Click here to subscribe.
Bihl+Wiedemann
Integrated IO-Link master
Whereas a 4- or 8-port master with an Ethernet connection was previously essential for the integration of perhaps just a single IO-Link device, Bihl+ Wiedemann now offers ASi-5 modules with one, two or four IO-Link master ports in various versions.
Bihl+Wiedemann
Portfolio expanded
Bihl+Wiedemann has expanded the ASi product portfolio with ASi-5 motor modules - on the one hand for direct control of roller drives with 24 V(DC) and 48 V(DC) via ASi, and on the other hand for decentralized control of three-phase AC drives with...
Bihl+Wiedemann
Security included
ASi-5 has the best prerequisites for the implementation of Industry 4.0 projects - especially with regard to the design of the transmission data. In addition, the communicative break between ASi-5 and TCP/IP isolates many network participants and...
