Phoenix Contact at the SPS 2024
Contactless energy and real-time Ethernet data transmission
© Phoenix Contact
The current variants of the 'NearFi couplers' from Phoenix Contact enable a doubling of the range for radio-based data transmission.
In addition, the devices offer double the power with automatic current equalization or the forwarding of two galvanically isolated voltages (US/UA) through parallel connection. The achievable range is doubled to up to 100 mm due to higher-performance radio boards during communication. The parallel connection of two NearFi coupler lines allows either the transmission of twice the power (up to 100 W) or of two electrically isolated voltages (50 W US/UA each). The IP65 devices from Phoenix Contact have new standardized M12 connections (L/D-coded) with a duo contour. This ensures flexible field wiring with classic M12 screw connectors or push-pull quick locking.
NearFi is a contactless real-time transmission technology that enables the transmission of power and data via an air gap. Thanks to protocol-independent and latency-free Ethernet communication, it opens up flexible application options for all Ethernet protocols up to 100 Mbit/s.
Hall 9, Stand 310
Belden
Flexibility in network design
Belden introduces the Hirschmann standard switch 'Greyhound2000' to the market. The 19-inch Ethernet switch offers a very high fiber optic port density and configurable port modules that can be flexibly adapted to different connection scenarios.
U.I. Lapp
»We need Air to breathe«
Lapp was not spared from the weakening global economy, but the company only recorded a slight loss in the 2024 financial year. Declines in sales in the European home markets were cushioned by gains in Asia.
Lapp
Changes in Corporate Management
Matthias Lapp is handing over his role as CEO of the EMEA region (Europe, Middle East, Africa) to Michael Seddig with effect from April 1, 2025. Lapp himself will concentrate on his duties as Chairman of the Lapp Group.
