Vision Components
MIPI cable up to 10 m
Vision Components meets the numerous connector variants for the MIPI-CSI-2 interface with a range of MIPI cables and customer-specific configuration options.
© Vision Components
Thanks to a 'SerDes' adapter board and the use of a coax cable, cable lengths of over 10 m can be realized with the MIPI interface. The FPC cable (Flexible Printed Circuit) is available in three standard versions with 15, 22 and 24 poles, in 60 mm, 100 mm and 200 mm lengths. It can therefore be connected to all standard single-board computers and CPU boards. With four lanes and a processing speed of 1.5 Gbit/s per lane achievable by most processors, transfer rates of 6 Gbit/s are possible, which corresponds to 750 Mbit/s with an 8-bit pixel resolution. The FPC cables have a trigger input and a flash output. They enable video streams as well as individual recordings. Individual settings such as shutter speed, gain, image size and position as well as binning can be adjusted for each image.
Vision Components at embedded world: Hall 2, Stand 450
Vision Components
In mini format
Vision Components has developed a complete embedded vision system that is barely larger than an image sensor module. PicoSmart System is suitable for the development of compact vision sensors.
