IoT connection
Alexander Lehmann | Meinrad Happacher,
Is Sigfox too limited?
The new, publicly available 0G network from Sigfox, which is currently being expanded worldwide, is specially designed for IoT connections, but is limited to 12 bytes per message. Can everything that OEMs need fit into such a message?
With 12 bytes, 2 to the power of 96 different values can be represented. In addition to an alive message - which here leads to a PHP-based message "HELLO WORLD"" any system status can be described with sufficient precision.
© Makaule, Dreamstime
We are no longer used to saving data. Bandwidths are constantly increasing, which is why hardly any attention is paid to clean HTML source code or pure text messages today. However, there is enormous market potential in limiting the new public 0G networks to just a few bytes. Fewer bytes mean less energy for data transmission and less payload also costs less money and also creates space in the communication channel for additional subscribers. This in turn saves costs for the infrastructure so that services can be offered more cheaply. It is precisely in this low-end, high-volume market that Sigfox's ultra-narrowband 0G network is positioned in order to connect all those things to the Internet that could not be connected until now because 3G/4G/5G broadband is too expensive, requires too much energy and cannot be used globally without roaming charges.
Strong in widely distributed infrastructures
Whether Microsoft Azure Cloud for Predictive Maintenance, Siemens Mindsphere Cloud or Cumulocity, they all support Sigfox's 0G network and connect to the Sigfox Cloud, which is hosted in Europe by Thales and is one of the most secure clouds in the world.
© Sigfox Germany
There is therefore a large market for the new 0G network in things and infrastructures that are often distributed across borders - from container and load carrier monitoring solutions to smart metering and monitoring the operation of pumping stations in the water supply. The charm of 0G logic for smart sensors and actuators of all kinds in such distributed systems lies, among other things, in the maintenance-free network connection, as there is no need to change batteries. Ultimately, for OEMs, they are nothing more than globally distributed devices that need to be monitored and managed centrally for better customer service.
Small messages, big benefits
12 bytes or 96 bits are only part of the overall communication stack. There is also a Length Indicator (LI), a Bidirectional Flag (BF), Repeated Flag (RF), a Message Counter (MC) and an Identifier (ID).
© Sigfox Germany
Sigfox can send up to 140 messages a day from devices of all kinds to IoT clouds (uplink) and four back to the device (downlink) for setting commands, parameterizations or function activations. However, the payload of the messages must not exceed 12 bytes. This is not a lot, which is why the network connection is also very energy-saving and inexpensive. With 12 bytes, however, 2 to the power of 96 different values can be represented. That is 79 quadrillions of different states. To clarify: a quadrillion is a number with 27 zeros before the decimal point! With this diversity, it should be possible to describe any system state with sufficient precision. Even complex global GPS coordinates only need around 6 bytes, so that the monitored objects can be localized precisely if required. But what solutions are there for transmitting various measured values, for example, if these add up to more than 12 bytes in purely mathematical terms?
Dos and don'ts when packing data
The data compression methods currently available are not very useful, as they hardly achieve any savings with the already very small data packets. The overhead of these algorithms is often greater than the savings that can be achieved with 12 bytes.
It also makes no sense, for example, to transmit only the small changes in relation to the previous position for geodata, because if the message with the first complete geoinformation is lost, the subsequent data string can no longer be reconstructed. For systems that would then allow alternative fallback access to the source data, this would not be the end of the world, but it is certainly better to design the system from the outset in such a way that it is not necessary to fall back on alternatives. For this reason, stateless communication, i.e. communication without reference to previous packets, has become established in message processing for 0G networks. No session information is exchanged and/or managed either.
However, it makes sense to split messages that are larger into several data transmissions using splitting procedures and to reassemble them in the cloud. If the existing data does not correspond to the 12-byte structure, it can be expanded using suitable bit and byte sequences.
Avoid redundancies
It also makes sense to reduce redundancies and optimize entropy, for example by no longer programming into the message that it is sensor x or machine y that is currently reporting here. It also makes no sense to send the type of value being transmitted, for example temperature or speed. This is because the devices already receive a unique identification in the cloud via the Sigfox ID, in which the assignment can be defined.
Unlike with Ethernet data packets, another tried and tested method is not to use a fixed data width. Instead, only the bit depth required by the measured values is used. For example, 7 bits (27 = 128) are sufficient for temperature values from -20 to 100 °C. This allows the payload of the Sigfox signal to be optimally utilized. This principle can also be used for yes/no values. If only the on/off information for six inputs has to be transmitted, this does not have to be coded in one byte, but only requires 6 bits with the appropriate set of rules. This means that this information can be transmitted together with only 13 bits. This saves 3 bits compared to pure byte values, which can be used for other data. In addition, the possible measured values can also be segmented into ranges, allowing the data to be communicated in a few message clusters instead of large numerical values with endless decimal places.
Not always explaining the whole world
It is also advisable not to transfer the geodata 1:1, but to reduce it logically in blocks, which saves bits as the area to be displayed is reduced. This can be useful for devices that do not leave countries or continents, for example. Because future GNSS chips will enable increased accuracy by evaluating the E5/L5 signals, these savings can then be used there. It also makes sense to create a specific table of states - ideally sorted by expected frequency - in order to assign shorter bit sequences to them. This procedure is called Huffman coding.
Set priorities!
If all these measures are not sufficient, messages can also be prioritized so that only the most important data is transmitted immediately if a threshold value is exceeded and other data is sent later. For example, data that is less critical can only be transmitted weekly or monthly, which, with 140 messages per day, leaves plenty of scope to transmit even the most exotic values to the cloud in order to collect all the necessary information over a slightly longer period of time. An "I am active" message can also be omitted entirely if other status information is transmitted regularly.
For complex predictive maintenance applications, it is also necessary to implement edge analytics anyway, for example to correctly interpret machine vibrations. Streaming such complex, sometimes gigabyte-sized data live in real time to central clouds rarely makes sense, at least for predictive maintenance, and is generally only of interest if the AI algorithm of the inference system is to be trained further in deep learning clouds. The message: The axis is now warped to such an extent that the CNC machine is no longer working within the tolerance range, but fits easily into 12 bytes.
Use memory on the Edge
Some customers also use local storage space for their data, which they read out via the BLE interface during maintenance work in order to then collect the complete data records via such complementary channels. For the simplest mobile IoT devices, such as charge trackers, it is often necessary to clarify how much flash memory the microcontroller used should have to store the data, as this is comparatively expensive for MCUs. For more complex embedded systems that are operated with larger ARM or x86 processors anyway, however, this memory issue is generally negligible, meaning that walk-by solutions consisting of a BLE interface and Sigfox as the primary reporting channel for the most important usage and predictive maintenance messages are an excellent combination, even for more complex devices.
Easy to implement in embedded systems
Manufacturers such as GCT offer hybrid components that integrate the stack for the parallel operation of 0G-Sigfox and 4G-LTE.
© Sigfox Germany
Sigfox's 0G network lies like a protective layer in front of the devices, machines and systems, making an IP-based hack on this device interface virtually impossible.
© Sigfox Germany
All of these measures are not rocket science for most embedded system developers in device, machine and plant engineering. They have already implemented sufficient logic and computing power in their solutions, which is why it should not be a hurdle for them to invest in logic to compress the data to the essential 12 bytes. However, some people may ask themselves why they should do this if they are selling a machine costing tens or hundreds of thousands of euros that they already have to connect to the network for software updates. This objection is certainly justified. However, even in these cases, there are some points in favor of using Sigfox: If the machine is only connected to the broadband network when it is really necessary, the attack surface for espionage and sabotage from the Internet is reduced in addition to the costs for a constant data connection. The 0G network can also be used as a fallback if the landline or mobile network fails, is overloaded in the event of a disaster or is disrupted by saboteurs via jammers. A 0G connection can also serve as an effective means for resets as part of out-of-band management. The French manufacturer of home entertainment platforms Free is leading the way: It uses Sigfox's 0G network in its 'Freebox Delta' all-in-one console for 10 Gigabit Internet, telephony, television, sound and home control to increase the availability of the system. So why not use the 0G network for industrial system monitoring and predictive maintenance applications, which usually only require a few message data for operational condition monitoring?
Suitable for industrial and mass applications
High interference immunity and EMI resistance as well as a high link budget for sparks through the reinforced concrete of many a factory hall are a given in any case. In this respect, Sigfox can also be made the standard for condition monitoring. In other words, the broadband internet is only connected when updates need to be carried out or data records need to be extracted to train new AI algorithms. This would definitely be both safer and more energy-efficient.
Author:
Alexander Lehmann is Principal Engineer and Technical Manager PreSales at Sigfox Germany.
Igus
Sensor provider Atronia acquired
Igus acquired a majority stake in the Portuguese company Atronia Tailored Sensing in March 2024. The sensor cooperation partner has been 'teaching plastic products from Cologne to feel' for five years.
Synostics
The planned shutdown
The aim of a correct maintenance strategy is to be able to predict a fault event in order to carry out the repair before the event occurs and thus before a machine failure.
