Ethernet IO modules
Quelle: Pepperl+Fuchs | Inka Krischke,
Integrated IO-Link master function
The Ethernet IO modules from Pepperl+Fuchs support common Ethernet protocols such as Profinet, Ethernet IP and Ethercat in one device. Thanks to the integrated IO-Link master function, end-to-end diagnostics and parameterization are possible.
© Pepperl+Fuchs
An L-coded M12 power connector offers up to 16 A current and reduces the installation effort. The multi-protocol function enables standardization in the machine, where previously different module types were required. A rotary selector switch is used to switch between the Profinet, Ethernet IP and Ethercat protocols. The integrated web server enables downloads, parameterization and diagnostic display. IO-Link-capable sensors and actuators can be connected, configured and parameterized via the integrated 8-fold IO-Link master. The fully encapsulated metal housing complies with protection class IP65/67/69 and measures 200 mm in length and 18 mm in height.
Hanover Fair
HANNOVER MESSE DAILY Day 4
The top news from the fourth issue: Robert Habeck at the trade fair tour +++ Technological AI highlights from Beckhoff +++ Radar sensor technology in focus at Pepperl+Fuchs +++ ASi-5 counter module as an active distributor from Bihl+Wiedemann +++...
Ecom
Securely networked even in the Ex zone
With the intrinsically safe 'Smart-Ex 03', Pepperl+Fuchs presents a 5G and Wi-Fi 6-capable smartphone for flexible use in public and private networks. Christian Uhl, Head of Communication at Pepperl+Fuchs, explains the special features.
