ICP Germany
Industrial Ethernet data acquisition systems
The 'SeaI/O Ethernet' series from ICP Germany can record and control digital and analog values remotely via the network.
© ICP Germany
The series is available in a desktop housing design and as an OEM version as a pure circuit board. It is addressed via 10/100 Base T Ethernet and supports Modbus TCP. In addition, the devices from ICP Germany can be integrated into your own applications via downloadable software libraries. Drivers for Windows and Linux as well as apps for IOS are available to access the EAs in the series. Various versions are available with digital and analog inputs/outputs or relays in a combination of eight to 96 ports to record values or control devices via the network. Digital inputs with 5 to 30 V(DC), analog inputs with 12 or 16 bit resolution and digital outputs with 12 bit resolution and setting ranges from 0 to 5 V(DC) or 0 to 10 V(DC) are available.
The "living" e-paper
Screen Edition 2024
Welcome to the first issue of the 'Screen Edition', which opens up a completely new way of reading and informing yourself: With the Screen Edition, we offer you a dynamic and always up-to-date source of information with its finger on the pulse.
Meilhaus
DC power supplies up to 200 W
B+K Precision's 'BK9240' series devices are universal DC power supplies whose multi-range power supplies extend the rated power from a point to a curve, delivering up to 200W over a wider range of voltage/current combinations.
