Ethernet switches
Easier integration into SCADA and HMI systems
The SDS-3008 Smart Switches - part of Moxa's family of Industrial Ethernet switches - provide users with an intuitive one-page dashboard that allows them to activate pre-configured industrial automation protocols with one click.
This facilitates integration into SCADA and HMI systems. The 20 mm × 135 mm × 111 mm switch supports Ethernet/IP, Profinet and Modbus/TCP. It can be configured with a single click via the intelligent Smart UI user interface. Thanks to its compact size, the switch fits into almost any control cabinet and enables both top-hat rail and rack mounting. Thanks to the three-way top-hat rail equipment, the switches can be installed horizontally or vertically.
