Wireless networks
Quelle: Steute Schaltgeräte | Inka Krischke,
Bidirectional communication
Steute's Wireless division presents components and functions of the sWave.Net wireless network. These components include a wireless terminal with a two-line display and three freely assignable buttons, which the operator can use to order supplies.
© Steute switchgear
Communication with the higher-level control system takes place via the sWave.Net wireless network. Access points, which work in a similar way to routers, send the radio signals directly to an IP address. Several hundred wireless switching devices of different types (such as position switches, foot switches, command devices or magnetic sensors) can be integrated into such a network. Data communication in an sWave.Net-based sensor network is bidirectional between the transmitter and access point. The same communication paths are preferably used as those created by synchronization.
Motek: Hall 7, Stand 7417
Lapp
Decentralized switches with IP67 protection
Lapp is launching switches for use outside the control cabinet: Thanks to IP67 classification, the Etherline Access PN IP67 Profinet switch and the Etherline Access U IP67 unmanaged industrial Ethernet switch are suitable for use directly in the...
Emnify
Is blockchain the future of the IoT?
Innovation does not always have to be disruptive; it can also be a synergy of two existing technologies. A current example of this is the combination of IoT and blockchain, i.e. the combination of connectivity and decentralization in the Internet of...
