ifm electronic
AS-i signals via fiber optics
ifm is launching an AS-i fiber optic repeater at SPS IPC Drives 2018. For the first time, AS-interface signals can be implemented via an optical medium and vice versa.
© Computers&AUTOMATION
Michael Strauss: "Our fiber optic repeater can also be used in a mixed network of ASi-3 and ASi-5. It connects remote ASi-3 segments to this mixed system."
AS-interface is characterized by the fact that data and power are transmitted on a 2-wire flat cable. Thanks to piercing technology, devices can be easily connected to the cable at any point. "With the AS-i fiber optic repeater, data and power supply are now separated from each other for the first time. This allows data to be transmitted over a distance of more than 3000 m via an optical fiber. This makes almost any network length possible," says ifm product manager Michael Strauss, describing the particular benefits of the new solution. "Especially in security technology, systems can be solved even more easily if all signals converge on one gateway."
Due to the optical transmission, there is no interference or grounding problems. This means that fiber optic transmission systems fundamentally eliminate the EMC risk. In addition, the fiber optic cable can be used for lightning protection and is insensitive to interference from EM radiation.
Systems with very large extensions can now also benefit from the specific AS-i advantages: "In open-cast mining, for example, safety elements such as rope pull switches or emergency stop buttons along the conveyor line can be wired with AS-i," says Strauss. In the process industry, where groups of sensors and actuators are distributed over long distances, the use of fiber optic repeaters further improves cost-effectiveness. As a side effect, the energy-free data transmission makes it possible to cross ATEX zones that would otherwise have to be bypassed over large areas.
The fiber optic repeaters are always used in pairs. AS-i signals, which are modulated onto the supply voltage, are converted into light signals on the transmitter side. The receiver transmits the data back to the next copper segment with the supply voltage. In this way, the optical fiber galvanically separates the network segments from each other.
Start-ups
The 'Automation Hackathon'
At the 'Automation Hackathon' at SPS IPC Drives 2018, seven start-ups had the chance to develop new business models for selected companies in the automation industry in 48 hours. Winner: the start-up Othermo in collaboration with Wago.
Synapticon
Entering the Machine Building Business
Known as a technology supplier to robot manufacturers, Synapticon now plans to offer targeted solutions for machine builders. The kick-off was given at the SPS IPC Drives with the ‚Actilink‘ drive systems and a quick-start package for the production...
