Photonfocus
With global shutter technology
Photonfocus launches the first UV camera with global shutter technology for machine vision applications within the 'photonSpectral' platform.
© Photonfocus
The camera offers a sensitivity of more than 40 % quantum efficiency from 170 to 820 nm. It is optimized for UV applications, but can also be used in the visible and NIR (near infrared) range. When used in industrial image processing, the high-precision UV camera technology benefits from global shutter technology, which ensures razor-sharp images of fast-moving objects.
The UV camera in the MV4 series uses backside-illuminated image sensors (BSI) to reduce noise, which improves image quality. With a frame rate of 140 fps at full resolution of 1280 x 1024 pixels, the camera captures even extremely fast processes. In addition, the UV camera is equipped with a C-mount lens connection and offers fast data transfer with the 10 GigE interface. The Photonfocus camera measures just 59 mm x 59 mm x 102.5 mm in its industrial-grade housing and can also be supplied with power via PoE (Power over Ethernet).
Compar
Artificial intelligence for image analysis
For soldered connections on printed circuit boards, the switch to lead-free solder causes increased failure rates. Quality control must therefore be improved. However, conventional methods with camera-supported automatic image evaluation quickly...
Inspecto
Autonomous machine image processing
Global competition and market expectations are putting increasing pressure on automotive manufacturers to improve their quality assurance procedures and switch to automated inspections. One challenge is to find the right machine vision method.
Deevio
End of manual visual inspection?
The widespread industrial use of artificial intelligence is still a long way off. Yet self-optimizing deep learning solutions are an important milestone on the way to the smart factory, which consists of AI-based production facilities and logistics...
