Matrix Vision
Waterproof and compact
For use in harsh environments, Matrix Vision offers a waterproof version of the 'mvBlueCougar-X' industrial camera with the IP67C option.
© Matrix Vision
The C in the name stands for compact, which is the main advantage. The watertightness has been integrated into the standard housing so that little installation space is required. The plug-in connections can be screwed on. There are two options for sealing the lens - either a standard lens is used in conjunction with a protective tube (available in lengths of 40 mm, 71 mm and 100 mm), or waterproof IP67 lenses are used. Kowa has added the latter to its portfolio as the BAM LS-VS-008 waterproof lens series.
Thanks to the various equipment options, the mvBlueCougar-X Gigabit Ethernet camera family covers the majority of possible application areas. The camera has various smart features such as flat field correction, color correction or white balance, which can be carried out directly on the camera.
Optometron
Space for microscopy and analysis
In quality control, space is often limited, so there is little room for microscope equipment. With the Doku-Kit3, Optometron offers a handy camera-monitor unit that enables self-sufficient microscopy and analysis without a PC.
ifm
Pallets automatically recognized
How can the productivity of logistics processes be increased and the effectiveness of Automated Guided Vehicles improved? One promising approach is a system for automated pallet recognition based on time-of-flight cameras.
