Vision & Control
Spot lighting with directional light guidance
27 spotlights with directional light guidance for industrial image processing are being launched by Vision & Control. Thanks to the modular design, users can configure the right lighting device for their specific purposes.
Spotlights from the SLE, SLB and SLF product families from Vision & Control
© Vision & Control
The spotlights in the SLE, SLB and SLF product families from Vision & Control are based on LED technology and have low power consumption. The light sources remain cool even in continuous operation. Depending on the model, the spotlights are available for different areas of the light spectrum - there are versions for white, blue, red and green light as well as for the ultraviolet and infrared range. Three different spot diameters - 100, 150 and 200 mm (each with a distance of 200 mm between the lighting device and the object) - are available. Depending on the version, the optical elements are made of glass or plastic. Within the variants, the user can choose from five different groups. Common features of all variants are protection class III for operation with safety extra-low voltages and protection class IP50.
SPS 2021
E-Paper THE OFFICIAL DAILY Day 2
Today's fresh issue of THE OFFICIAL DAILY Day 2 has plenty of news for you and keeps you up to date with all the trends and developments in the industry. The "Click-here" button will also take you to additional features. Try it out for yourself.
Vision & Control
Optimized for blue light
Within the visible spectrum, monochromatic image examinations with blue light are the most effective. The lenses in the Blue Vision series from Vision & Control are specially designed for this spectral range.
Wenglor
Precise illumination
The new spotlights from Wenglor with lockable zoom lens for a variable beam angle in the range from 4 to 26 ° with constant homogeneity enable a pinpoint lighting situation.
Basler
Modular board level camera
With the 'dart M', Basler is launching a customizable board-level camera with GigE interface that adapts to the installation situation and existing electronics of the customer application thanks to its modularity and design.
