Autovimation
Protective camera housing with water cooling
© Autovimation
Autovimation launches its first camera protection housing with an integrated water cooling circuit.
The housing from the 'Elefant' series is suitable for cameras up to 100 mm x 100 mm cross-section. All sides of the housing, including the front and rear covers, have cooling channels running through them - the total length is almost 7 times the length of the housing. The air conditioning allows camera operation at ambient temperatures from -40 to +200 °C. The associated rear cooling unit with pump, radiator and monitoring of camera temperature, volume flow and fan can be operated at a distance of up to 20 m. Various viewing windows, the 'Meganova' LED ring light, wind curtains and protective flaps are available as accessories. Autovimation also offers an assembly kit with lightweight, robust dovetail profiles for setting up inspection systems.
Basler
The long-standing Basler CEO Dr. Dietmar Ley will be leaving the company at the end of the year and will be succeeded by the current CCO/COO Hardy Mehl. The CTO position will be filled externally by Dr. Kai Jens Ströder.
