High Speed Vision
75 Gpx/s data transmission
The Phantom TMX 7510/6410 cameras from High Speed Vision have a back-illuminated CMOS image sensor.
© High Speed Vision
According to High Speed Vision, the (back side illuminated or BSI) sensor technology significantly increases the efficiency of the individual image pixel and increases the data throughput. This ensures a data transfer rate of 75 Gpx/s for all frame rates and image resolutions. At the same time, a very high light sensitivity (monochrome 40,000 ISO and color 12,500 ISO) is achieved compared to conventional CMOS sensors. With an image resolution of 1280 x 800 pixels, the camera offers a frame rate of 76,000 fps, in reduced resolution in 'Fast Option' mode up to 1,750,000 fps (minimum exposure time 95 ns). In binned mode (2 x 2 pixels), the light sensitivity and frame rate are further increased.
Further performance data include very fast RAM memory of 128 to 512 Gbyte, which can be divided into up to 511 partitions (ring memory). A high download speed is available via the 10 Gbit Ethernet interface.
Teledyne Dalsa
Reliably sorted and packaged
Sorting food manually is time-consuming, strenuous and error-prone. It is therefore only logical to rely on automation with the support of image processing, as a look at two companies belonging to the Unilever Group shows.
MVTec
The 'eye of production'
Machine vision makes a significant contribution to the end-to-end automation and optimization of production chains. If artificial intelligence methods such as deep learning are used here, process efficiency can be further increased.
Compar
Artificial intelligence for image analysis
For soldered connections on printed circuit boards, the switch to lead-free solder causes increased failure rates. Quality control must therefore be improved. However, conventional methods with camera-supported automatic image evaluation quickly...
