Turck
Fast interfaces for Ethercat
With the TBEC family, Turck is expanding its range of robust and compact RFID solutions with fast interfaces for Ethercat networks.
© Turck
The 'TBEC' module in a fully encapsulated plastic housing is designed with IP67/IP69K protection and can be used in an extended temperature range of -40 to +70 °C. The Ethercat RFID module allows parallel operation of HF and UHF read/write heads. Like all Ethernet multiprotocol devices from Turck, the 'TBEC' also supports the HF continuous bus mode, by means of which up to 32 bus-capable HF read/write heads can be connected to each of the four RFID channels. In applications with many read or write positions, this reduces wiring effort, costs and commissioning times.
Sensors, lamps or other actuators can be connected to the eight universal DXP I/Os. All connections are designed as 5-pin plug connections in M12, the power supply (L-coded) is provided via M12 power technology.
