Bopla
Customized input systems
With the capacitive membrane keypads from Bopla, sensors and evaluation electronics can be integrated into a compact input unit instead of being separated from the user interface on the circuit board, as is usually the case.
Capacitive membrane keypads
© Bopla
This is made possible by hybrid electronics, which can be used to flexibly equip free-form surfaces with individually designed touch sensors. This can be printed as a single button, slider or matrix directly on the respective user surface - glass, acrylic glass, housing cover, etc. - or on a separate film. Such a touch sensor foil can be stuck onto any surface to transform it into an input unit.
According to the manufacturer Bopla, the sealed surface is guaranteed to function perfectly even when exposed to moisture, aggressive liquids, dirt and other contaminants. As the capacitive input units are easy to clean, they can be used in harsh industrial environments as well as in hygienically clean environments.
Friedhelm Loh Group
Managing Board expanded
The Friedhelm Loh Group is aligning its group of companies for the future and is expanding its Executive Board to include Prof. Dr. Niko Mohr. He joins owner and CEO Prof. Dr. Friedhelm Loh and CFO Ralph Lindackers on the Executive Board.
