Servo drives
Rockwell Automation | Inka Krischke,
Power ranging 1.6 through 60 kW
In the Allen-Bradley Kinetix 5700 Rockwell Automation enters the market with a new servo drive. This comes with dual servo axes, a 1.6 to 60 kW power range and ready technology for tuning.
© Rockwell Automation
Instead of implementing multiple servo drives, with this platform machine builders can cut the space needed in a control cabinet by as much as 70 %, plus more than 60 % less wiring effort, to simplify configuration and commissioning. For realtime control the drive uses load observer technology (monitoring of changing mass inertia relations). That does away with the need to manually tune each single axis. As soon as a machine is ready to operate, a tracking notch filter detects and eliminates resonant frequencies. Tuning automatically optimizes machine performance. The drive combines powerful asynchronous motor control with servomotor control - intended to reduce machine complexity and save time and cost to integrate. Plus, in the Rockwell Studio 5000 Logix Designer software the user has a development environment to configure the servo drive.
IIoT gateways
Based on Raspberry Pi
With the RevPi-Connect, Kunbus introduces the newest member of its Revolution Pi product family to the market. The device, designed as an IIoT gateway for machine and plant construction, is housed in a DIN rail housing.
