Faulhaber
High performance, compact design
With the new linear actuator family L, Faulhaber provides a turnkey solution for a wide range of applications.
© Faulhaber
The smaller versions 06L/08L/10L of Faulhaber 's linear actuators are suitable for applications in the fields of medicine, laboratory automation, optics and photonics or aerospace. The larger 22L/32L versions use the latest GPT gear technology and are designed for applications in industrial automation, optics and photonics. The linear actuators can be combined with a wide range of DC motors, four-pole and two-pole brushless motors or stepper motors. They are optimized to make the best possible use of the torque and speed range of the various Faulhaber motor families. The manufacturer has developed the L family for high performance with compact dimensions. High input speeds or high output forces are supported.
Faulhaber
Motor series extended
Faulhaber has expanded the BXT flat motor series to include gears that are matched to it as well as integrated encoders and speed controllers, which are also unusually short in the axial direction, according to the manufacturer.
Lean technology
Easy to implement
