Sensirion
Temperature and humidity monitor
FiveCo launches data loggers under the brand name 'THEye', which monitor the temperature and humidity of the environment for various applications.
SHT3x temperature and humidity sensor series from Sensirion
© Sensirion
The THEye TH-2 data logger, for example, monitors the temperature and humidity of its surroundings using an adjustable measuring frequency. It has a memory capacity of up to 172,000 data points and uses the latest Bluetooth Low Energy technology. For precise results, the company relies on the SHT3x temperature and humidity sensor series from Sensirion. This sensor series combines a wide range of functions and various interfaces (I²C, analog voltage output) with an application-friendly and wide operating voltage range (2.15 to 5.5 V). THEye is available in two versions with different temperature accuracy. Both versions are equipped with sensors from the series. The THEye TH-2 ISO incorporates the SHT33-DIS, whose ISO17025 certification allows the logger to be designed in compliance with the cold chain.
Sick
Award for sustainability management
Sick has received a platinum medal in the EcoVadis sustainability ranking. This puts the provider of sensor-based automation solutions in the top 1 percent of more than 130,000 companies worldwide that have been assessed over the past twelve months.
