Baumer
Miniaturized laser distance sensors
The 'OM20' and 'OM30' laser distance sensor families with IO-Link from Baumer can be used flexibly in many applications thanks to their measurement performance and compact design.
© Baumer
According to the manufacturer, they offer reliable, surface-independent measurement with a repeat accuracy of up to 1 µm and a measuring speed of up to 5 kHz. All this is integrated into the OM20 in a housing size of 37 mm x 35 mm x 13 mm. For measurements on structured surfaces such as machined metals or wood, the OM30 distance sensor family offers a reliable solution thanks to its line beam shape with a range of up to 550 mm.
The standardized IO-Link interface enables easy integration into the control system and parameterization of the sensor. In addition to standard process data such as the distance value or the signal quality, additional data such as the measuring rate and the exposure reserve of the sensor are also available. The latter can be used as an indicator for sensor contamination and thus support predictive maintenance concepts.
Baumer
Optimal use of IO-Link
The Baumer Sensor Suite is a PC software for the development and use of smart sensor solutions. Its intuitive operation and graphical representation of sensor functions make it easier to evaluate, select and parameterize IO-Link devices.
Baumer
Process transparency through color display
When measuring the limit level with the 'CleverLevel PL20' limit level switch from Baumer, five defined colors of the KingCrown process visualization provide an insight into whether the limit level has been reached, which medium is in the tank or...
Baumer
The all-round view
Rotationally symmetrical objects in the pharmaceutical, food and beverage industries are often rotated once around their own axis during inspection and the images captured in the process are compiled afterwards. An alternative is a system with four...
Megatron
Angle measurement in the smallest space
Thanks to their housing depth of just 6 mm and a housing diameter of 16.4 mm, the hollow-shaft conductive plastic potentiometers in the 'MHP16' series from Megatron are particularly suitable as position indicators in motor valves and actuators.
Leuze at the SPS 2024
Double focus
With the 'DCR 1048i OCV', Leuze is expanding its Simple Vision portfolio with a further functionality: The sensor can both read 1D/2D codes within an application and check the quality of a print using the OCV method.
