Leuze at the SPS 2024
Double focus
© Leuze
With the 'DCR 1048i OCV', Leuze is expanding its Simple Vision portfolio with a further functionality: The sensor can both read 1D/2D codes within an application and check the quality of a print using the OCV method.
This makes it possible to determine whether the best-before date, batch or other printed information is present, complete and legible. For print quality verification via OCV, users can teach in the vision sensor from Leuze without complex parameters. It is sufficient to present a reference image of the optimum print. The sensor then detects faulty prints - for example, clogged print heads, used ink or adhesion problems. The threshold value is adjustable. Products detected as defective can be ejected.
Hall 7A, Stand 230
