Sensopart at the SPS 2022Time-of-flight sensor with red light
The FT 25-RLHP time-of-flight sensor from Sensopart works with red light and detects objects up to 1.5 m away.
11 of 13
© Jumo
Jumo is expanding its safety performance portfolio with a measurand that enables the safe detection and measurement of process-critical limit levels and fill levels of liquids. The manufacturer offers solutions for the measuring point up to SIL 2 in accordance with IEC 61508. This is a system solution based on the products of the Nesos series and is available in various expansion stages. Flexible options are available, ranging from SIL-qualified sensors with all the required safety-related characteristic values to certified measuring points. The complete JSP solution in the 'level' area also detects line faults. Solutions can also be implemented in combination with applications in explosion-proof areas and flameproof enclosures as well as in shipbuilding. The JSP portfolio includes complete solutions for temperature, pressure and level. If repeat testing needs to be carried out again, customers have the option of factory testing including documentation and product marking.
SPS 2022: Hall 4A, Stand 445
11 of 13
