Siko at the SPS 2022Absolute encoders for Industry 4.0
The WV3650M and WH3650M absolute rotary encoders from the second generation of Siko's 3 mm series are compact and, thanks to their new architecture, interfaces such as IO-Link and smart features, are a solution for Industry 4.0 machine concepts.
Jumo's programmable pressure transmitter Jumo Siras P21 AR/DP is approved for use in safety-related systems with Safety Integrity Level (SIL) in accordance with DIN EN 61508 and Performance Level (PL) in accordance with DIN EN 13849, making it suitable for safety measuring chains in the process industry and suitable for a wide range of applications. It measures the relative, absolute or differential pressure of liquids, vapors and gases. As an extension of the supplier's safety performance portfolio, it can be used in combination with the 'SafetyM STB/STW' safety temperature limiter and the transmitter power supply unit as a ready-to-use safety chain for SIL2 or SIL3. The factory-set measuring ranges are up to 100 bar relative pressure and up to 100 bar absolute pressure. The long-term deviation is less than 0.1 % per year and the linearity is 0.05 %. According to the manufacturer, all wetted materials are made of stainless steel, so that CIP cleaning is also possible.
SPS 2022: Hall 4A, Stand 445
