Siko at the SPS 2022Absolute encoders for Industry 4.0
The WV3650M and WH3650M absolute rotary encoders from the second generation of Siko's 3 mm series are compact and, thanks to their new architecture, interfaces such as IO-Link and smart features, are a solution for Industry 4.0 machine concepts.
The Zelos C01 LS from Jumo detects the level of liquids and solids and can be used at temperatures between -40 and +200 °C. It can also be used in pressurized tanks or pipes. It can also be used in pressurized tanks or pipelines. Once configured, the two switching outputs can automatically differentiate between measuring medium and cleaning media or foam. Installation is carried out using a standard torque wrench. Short-circuit and reverse polarity protection provide additional safety. An antivalent circuit detects line faults such as a cable break. A firmware update profile allows the sensor to be updated while installed, minimizing system downtimes. PNP, NPN, Push Pull and IO-Link are available as output signals. A status display indicates the sensor status in accordance with NAMUR and VDI/VDE. The detector also has IP67/IP69 protection and meets the requirements of intrinsically safe explosion protection, the German Water Resources Act and electrical safety in accordance with UL.
SPS 2022: Hall 4A, Stand 445
