Contrinex at the SPS 2025
Weld-proof sensors with remote monitoring function
Contrinex inductive Weld-Immune sensors are coated with a durable, anti-adhesive 'Activestone' ceramic coating that allows weld spatter to slide right off the surface.
© Contrinex
In the automotive industry, the sensors detect the position of the sheets to be joined with switching distances of up to 16 mm. The ceramic coating was specially developed for use in MIG, MAG and spot welding applications. Its non-stick, abrasion-resistant surface prevents spatter accumulation and simplifies sensor maintenance. Activestone is insensitive to thermal and mechanical stresses. The weld-resistant inductive sensors also have a one-piece stainless steel housing (V2A / AISI 303) and therefore resist magnetic interference from medium-frequency welding fields (current up to 15 kA) and are extremely shock-resistant. The temperature of the sensors can be monitored via IO-Link - an alarm is generated if a predefined threshold value is exceeded. IO-Link also provides access to the output switching function, the LED function and a counter with threshold value alarm.
Hall 7A Stand 430
Sick
Sales growth in a turbulent market environment
Thanks to innovations and a focus on strategic industrial markets, Sick was able to moderately increase its sales in the 2025 financial year. In a turbulent market environment, the company was able to maintain its position and gain market share with...
