Sick for SPS Connect
Contactless measurement
With 'Speetec', Sick is expanding its existing portfolio for measuring the speed and length of linearly moving objects with a technology that measures directly on the material surface with an accuracy of a few micrometers.
© Sick
For sensitive, soft or smooth surfaces, customers in factory or logistics automation require non-contact measurement options for the length, speed and position of continuous webs and blanks in order to avoid damage or contamination. According to the manufacturer, the non-contact 'Speetec' closes the gap between tactile, indirect measuring encoder solutions and more expensive laser velocimeters. It can measure without slippage, without measuring standards or markings and without wearing out tactile measuring elements. This means that materials that affect tactile measuring solutions such as measuring wheel encoders through abrasion, adhesion or wear and impair their function and service life can be measured reliably. According to Sick, the return on investment (ROI) for 'Speetec' is less than one year.
Speeds up to 10 m/s
Speetec' is equipped with class 1 lasers. The non-contact measurement is carried out using the laser Doppler method at speeds of up to 10 m/s. Two transmitters emit laser light - once with the direction of travel of the material, once against it. As both transmitters work independently of each other, possible assembly tolerances and surface fluctuations can be compensated, for example in the case of wavy surfaces. The accuracy in relation to an object length of 1 m is 1 mm with a resolution of 4 µm. In this case, the repeat accuracy is specified at 0.5 mm. Measured values are output via TTL or HTL interfaces, which are common in the encoder world.
Speetec' can be used to measure length, speed and position in linear movements, even with alternating forward and backward movements. As only 3 ms elapse between the start of the movement and the measured value output with the sensor, it is also possible to measure accelerations in applications with high movement dynamics. According to the manufacturer, comparable systems are significantly slower here. The speed sensor also creates new resource-saving solutions for measuring the speed of short materials: While velocimeters often require several meters of material lead time, 'Speetec' can reliably measure individual parts the size of a business card.
Sick
New Management Board structure
The Sick Management Board will be expanded as of January 1, 2021: Feng Jiao has been newly appointed to the Management Board and will be responsible for Sales & Service. Dr. Mats Gökstorp, previously responsible for Sales & Service, will...
TDE Instruments
Modbus interface included
The Digalox series of measuring devices from TDE Instruments is now also available with a Modbus interface. According to the manufacturer, the graphical multifunction measuring devices with RGB backlighting offer extensive functions and display...
Sick
Scans an area of up to 200 m²
With the 'TiM2xx' product family, Sick is expanding its range to include 2D LiDAR sensors for localization and anti-collision applications. The TiM240 is the first variant in the series and complies with protection class IP65 for indoor use.
3D cameras
Sick and Microsoft cooperate on 3DToF
Together with Microsoft, Sick wants to drive forward the development of commercial industrial 3D cameras and related solutions. These are compatible with a Microsoft ecosystem based on the Microsoft Depth, Intelligent Cloud and Intelligent Edge...
Sick
Taking IO-Link further
Automatically detecting all IO-Link devices in a machine, automatically downloading their device descriptions and parameterizing and monitoring them over their entire life cycle independently of the control system and fieldbus - a software tool...
