ifm at the SPS 2021
Combinable 2D inspection of surfaces and contours
Missing retaining clips, unmilled threads, too much adhesive or an incorrectly shaped component: the Dualis from ifm detects this and any other deviation of the test part from the specified target state.
© ifm
Surface areas, contours, omissions or object rotation can be viewed and evaluated individually or in combination. Thanks to the integrated daylight filter, the sensor is resistant to ambient light. The version with integrated polarizing filter is particularly suitable for applications with highly reflective objects.
The sensor is set up using the 'Vision Assistant' software from ifm. According to the supplier, real-time maintenance options ensure reliable quality assurance. For example, changes in the continuously checked image sharpness and image brightness indicate an unintentional misalignment. In this case, the sensor can automatically issue a warning.
The sensor is equipped with a stick on which the parameters are stored. In the event of a device replacement, the stick can be used to transfer all the settings and parameters required for operation.
ifm at the SPS 2021: Hall 7A Stand 302
ifm
Innovation and quality
Measuring, controlling, regulating and evaluating - when it comes to pioneering automation and digitalization technology, the ifm group of companies is the ideal partner.
Leuze at the SPS 2024
Double focus
With the 'DCR 1048i OCV', Leuze is expanding its Simple Vision portfolio with a further functionality: The sensor can both read 1D/2D codes within an application and check the quality of a print using the OCV method.
