Siemens
Certification up to SIL 3/ PL e
With the Sirius 3RQ1 series, Siemens Smart Infrastructure is completing its portfolio of coupling relays for electrical systems in industry and infrastructure.
© Siemens
The positively driven devices can be used universally with a wide-range supply voltage of 24 to 240 V(AC/DC) and are certified up to SIL 3/ PL e. The coupling relays can switch electrical loads directly. Thanks to their forced operation in accordance with IEC 60947-5-1 (IEC 61810-3), the devices offer safety for people and systems. For example, they enable brakes and doors to be controlled safely and traffic lights, conveyor belts or packaging machines to be switched.
The coupling relays offer additional safety as an output extension of the 'Sirius 3SK' series safety switching devices using a device connector. The coupling relays themselves can be wired vertically thanks to removable terminals with screw connection or spring-cage technology (push-in).
Siemens
Edge rack server in robust
The trend towards hyper-convergent infrastructures is not stopping at the manufacturing and automation industry. Siemens has now launched the first edge rack server in robust industrial PC quality. How is the inner workings of the server designed?
Siemens
For personal use
Siemens operates vertical farming for its own use at its site in Frankfurt. Siemens technology is used here. What works here on a small scale is also a future field for agriculture in general.
